KB-28633: TCP/IP port for connecting the Viewer.
Question:
What port is used by the Viewer?
Solution:
The Viewer’s default port for connecting to the Server is 6515. This port is set up by REC protocol, used for connections with E3Server, E3Viewer, and E3Studio. You can change the number of the port via E3 Tweak.
Print Friendly, PDF & Email
Leave a Reply
