Question:
Why is an OPC tag imported from an E3 Server displayed as folder containing several properties?
Solution:
OPC tags are imported as folders containing its main properties. If necessary, you can import only a certain property (however, it must be renamed, because several tags will share the same property); it is also possible to import all tags and delete the properties that will not be used in the OPC.
NOTE: Please notice that each property counts as a different tag, for the license’s tag count purposes.
