KB-28575: Accessing an Altus OPC Server installed in a different computer.
Question:
To access the Altus OPC Server Driver from a different PC, do I need to have an OPC Driver installed in my own computer? Or can I access the Server from the other machine?
Solution:
No, this is not necessary; you just need to find the machine with the OPC Server on the network.
Print Friendly, PDF & Email
Leave a Reply
