KB-28571: SCADA full screen closed with Ctrl+F4.
Question:
Why is a SCADA full screen being closed when pressing Ctrl+F4?
Solution:
This is SCADA’s standard behavior. To change it, you can use the Ctrl+F4 combination in an OnKeyPress() event, in order to invalidate the close screen function.
Print Friendly, PDF & Email
Leave a Reply
