KB-28541: Communicating with Siemens S7-200 CP243 via Ethernet.
Question:
Can MProt driver communicate with S7-200 CP243 via Ethernet?
Solution:
Yes, it can. To do so, just check the ISOTCP243 option in the Network field, and configure the Ethernet tab.
Print Friendly, PDF & Email
Leave a Reply
