KB-28535: Sharing directories for Remote Domains.
Question:
In the Domain File, why do I need to inform the shared directory where application to be accessed is?
Solution:
You must do this so that E3 will access the remote application’s objects via AppBrowser, and also for the created links are indicated correctly. If you don’t fill in this property, all links for the remote application will appear in red (even when correct), thus compromising the application.
Print Friendly, PDF & Email
Leave a Reply
