Question:
What is the difference between InTime, OutTime, and E3TimeStamp properties?
Solution:
- InTime: records date/time of the value when it gets in alarm.
- OutTime: Records date/time of the value when it gets out of alarm; or zero (12/30/1899), if the alarm is still active.
- E3TimeStamp: this field is set by E3Run, and contains the date/time when E3Run sent the event to the Database.
