Question:
I have successfully recorded data in a Formula. However, when I try to load these values, I notice they have been rounded up (for example, value 16.7 becomes 17). How can I fix this?
Solution:
This may have happened due to the data type being used by the Formula. To fix this, you can set it up at the Template field as Double, which is the format that enables storing decimal values.
