Question:
In an E3 application, data can be successfully recorded in a Formula; however, when I try to load these values via LoadFormulaValues method, the following error message is displayed: “Value informed is not a valid Double”. Why is it happening, and how can I fix this?
Solution:
This problem has occurred because your user regional settings (decimal separators, etc.) differ from SYSTEM’s user regional settings. To fix this situation, both settings must be the same.
To change your user settings, you must access the option Regional Settings. To change SYSTEM’s user settings, use the following register key: HKEY_USERS\.DEFAULT\Control Panel\International.
