KB-28426: Tag license not released even when the tag is deactivated.
Question:
Why are the tag licenses not released when this driver’s objects are deleted or deactivated at run time? And if a few settings are altered, why does the driver display license issues?
Solution:
At run time, each time either the driver or the tags are altered, the tag licenses will be consumed again. If a tag is deactivated and then reactivated with the SAME settings, the license will NOT be added. A new license will only be added if any parameters are altered too.
Print Friendly, PDF & Email
Leave a Reply
