KB-28396: Oracle set up in the same machine as E3Server.
Question:
How can I set up an Oracle database in the same computer running E3Server?
Solution:
To do so, just leave Connection field blank in the database settings. You will not need to install the Oracle client.
Print Friendly, PDF & Email
Leave a Reply
