Question:
Where can I place a warning message that there has been a Viewer Only restriction so that I don’t have to change this information in each button’s script individually?
Solution:
There is no “generic” place for this. In the case of libraries, just change the XControl’s definition. But for inserting buttons that don’t use libraries, you will need to create a verification script for each button.
