KB-28374: Using the WebViewer via Windows Mobile.
Question:
Can I use the WebViewer via Windows Mobile?
Solution:
Neither the E3WebViewer nor the E3Viewer can be accessed directly in a pocket running Windows Mobile. One alternative is to access another machine running Windows via the pocket’s Remote Desktop Connection, and then use this machine to use the Viewer to access the application.
Print Friendly, PDF & Email
Leave a Reply
