KB-28355: Recovering corrupted application.
Question:
How can I recover an application from the .BAK file after the .APP file had been corrupted?
Solution:
To do so, follow these procedures:
  1. Delete the corrupted .APP file.
  2. Then, open the .BAK file on Elipse SCADA at File Type–All Files.
  3. Go to File, select Save Application As… option, save it as .APP, and then resume working with .APP.
Print Friendly, PDF & Email
Leave a Reply
