KB-28296: Maximum amount of Historic fields when using Access DB. 25 de March de 2019Elipse SoftwareLeave a Comment on KB-28296: Maximum amount of Historic fields when using Access DB. Question: What is the maximum amount of Historic fields when using Access DB? Solution: You can use up to 127 fields: for each field created in the Historic, another one is created in Quality field. Este artigo foi útil? Was this helpful? Submit Rating Classificação média - Average rating 0 / 5. Count: 0
