KB-28280: Opening E3 v. 3.1 using hardkey v. 2.5.
Question:
After updating Elipse E3 from version 2.5 to version 3.1, can I open an application on the newer version without upgrading the hardkey?
Solution:
No, you can’t. To open the application, you must upgrade the hardkey too.
Print Friendly, PDF & Email
Leave a Reply
