Question:
After having formatted the computer and correctly installed Elipse SCADA, the application being executed displays the following error message: “The DAO.dll file was not found “. How can I fix this?
Solution:
To do so, you must install the DAO Kit, which can be downloaded directly from Elipse Software’s website.
