KB-28006: E3 application hangs when OPC Server cannot communicate with the PLC.
Question:
How can I keep an OPC Client from hanging when it cannot communicate with the PLC?
Solution:
To do so, you must set your OPC Client’s ServerId property as blank. Thus, it will run without attempting to communicate with the OPC Server.
Print Friendly, PDF & Email
Leave a Reply
