Question:
When I run the Print Preview command, a red dotted line is displayed vertically on the window with the report’s data. How can I remove this line?
Solution:
This line is an automatic limiter, which only appears in the Print Preview to show that the report is larger than the paper set up for it. To remove this line, you will need to either shrink the report or use a larger paper format.
