KB-27897: Charts not displaying data after E3 is updated.
Question:
Why do the charts stop displaying data when updating E3 from version 2.0 to version 2.5?
Solution:
This happens because the fields set up in the pens have blank spaces. To fix the problem, just set each field between brackets.
Example: [field name]
Print Friendly, PDF & Email
Leave a Reply
