KB-27768: E3Query retrieving data from an Oracle view. 25 de March de 20197 de March de 2023Elipse SoftwareLeave a Comment on KB-27768: E3Query retrieving data from an Oracle view. Question: How can I set up an E3Query to retrieve data from an Oracle view? Solution: To do so, just use the SQL SELECT command to select the data the same way you would do with any Database table. Este artigo foi útil? Was this helpful? Submit Rating Classificação média - Average rating 0 / 5. Count: 0
