KB-27638: Communication between SCADA applications.
Question:
Can data from a SCADA application be acquired via another one?
Solution:
Yes. To do so, there are two options:
  • Via Remote Applications (but you need to purchase a PRO license and use the TCP/IP driver for this option).
  • Via OPC communication.
Print Friendly, PDF & Email
Leave a Reply
