KB-27564: Opening PDF and HTML files and websites on an E3 screen.
Question:
Can I open a TXT, PDF, or HTML file, or a website, on a screen in Elipse E3?
Solution:
Yes. To do so, you can either open it on a frame by indicating the folder’s path at SplitLink property, or use the Open Screen pick by indicating the path at Open Screen field. In case you want to open a website, use its complete address. Ex.: http://www.elipse.com.br.
Print Friendly, PDF & Email
Leave a Reply
