KB-27418: Storing historic alarms in E3Alarm.
Question:
Can E3Alarm store the acknowledged alarms that have already returned to the normal status? That is, is it possible not to remove them from the list, so that they remain as historic?
Solution:
No, this can’t be done. E3Alarm displays only active and/or unacknowledged alarms, not historic alarms.
To display the alarms historic, you must use E3Browser.
Print Friendly, PDF & Email
Leave a Reply
