Question:
In an application, a few Rectangle objects are used to draw a diagram. With zoom set to 400%, the rectangles’ borders fit perfectly, but when the zoom is set to 100%, the figures are overlapped. Why does this happen?
Solution:
This happens due to the zoom settings and the conversion calculation from Pixel to HIMETRIC. To work around this, you can set up an anchor point for each rectangle, by right-clicking it and choosing Set Anchor Point option. After that, drag each rectangle’s anchor point to the same point on the screen.
