KB-27407: I/O Blocks.
Question:
What are I/O Blocks for?
Solution:
I/O Blocks optimize the communication. For example, when there is a sequence of addresses in the device, the I/O Block will read all the addresses at once, instead of doing it individually.
In the I/O Block settings, the first element corresponds to the address set up in the Block Tag, the second one corresponds to this address plus one (+1), and so on.
Print Friendly, PDF & Email
Leave a Reply
