Question:
Can only a specific batch be deleted in Elipse SCADA?
Solution:
Yes, it can. To do so, you must pass all batches to temporary .DAT and .HDR files, leaving in the original .DAT and .HDR files of the application only the one you want to delete. Then, copy the data from the temporary files to the original ones.
NOTE: Attached to this article is a sample application, developed in Elipse SCADA v. 2.29 build 92.
