Question:
Which are the differences between Elipse E3 and Elipse SCADA?
Solution:
The main differences are:
- While Elipse SCADA was developed for stand-alone applications, Elipse E3 has a Server-Client structure that enables operating on several workstations.
- E3 has its own graphic editor.
- You can create Libraries in E3.
- E3 has native redundancy tools (Hot-StandBy).
- E3 supports ActiveX.
- E3‘s Historics do not use a proprietary structure, such as Elipse SCADA‘s.
- E3 enables playback to view application’s screens using historic data.
Check Elipse Software‘s website for more information about these products.
