KB-27256: Gallery restrictions in demo mode and versions compatibility.
Question:
Can I use figures from E3 Gallery in Demo mode? If the application was developed in the E3’s v. 3.0 , can I execute it in v. 2.5?
Solution:
In Demo mode, only the first figure from each gallery is available for use. To use the other ones, you will need a hardkey.
An E3 application cannot be executed in any version prior to the one where it was configured. So, an application developed in E3 v. 3.0 can only be executed in v. 3.0 version or higher.
An application developed in v. 2.5 can theoretically be executed in v. 3.0, but we recommend that you execute applications in the same version where they were configured.
Print Friendly, PDF & Email
Leave a Reply
