KB-27186: Communicating with PLC S7200 via USB serial converter. 25 de March de 2019Elipse SoftwareLeave a Comment on KB-27186: Communicating with PLC S7200 via USB serial converter. Question: How can I establish communication with a PLC S7200 by using a USB serial converter? Solution: To do so, since the driver will always keep its parity as EVEN, you must set the PLC as EVEN too. Este artigo foi útil? Was this helpful? Submit Rating Classificação média - Average rating 0 / 5. Count: 0
