KB-27150: Date in FILETIME format in E3.
Question:
Can I work with FILETIME dates on E3?
Solution:
No, you cannot, because this type of data uses 64 bits and works with a resolution of 100 nanoseconds starting on the year 1601. Thus, we suggest that you use the DATE format, which is the same one used in E3.
Print Friendly, PDF & Email
Leave a Reply
