Question:
In the application, I have the following folder structure for alarms:
alarms\general\se01\switch01
\switch02
\switch20
How can I set up the return all alarms from all switches of a certain substation in an SQL query?
Solution:
To do so, you must use the “%” character. For example, if you want to know the alarms from substation “se01“, use:
alarms\general\se01\%
