Question:
Why is the following message being displayed in Elipse E3?
THE OBJECT COULD NOT BE LOADED CORRECTLY BECAUSE SOME OBJECTS’S CLASSES WERE NOT FOUND. USE “CHECK THE DOMAIN” OPTION FOR FURTHER DETAILS.
Solution:
What probably happened is that a LIB file was deleted, but its reference remains inside the domain, which tries to load it, fails, and then displays this error message. To fix this, try creating a new domain and re-inserting all projects and libraries files that had been used.
