Question:
Why are the bidirectional and reverse links not imported correctly in my application?
Solution:
Simple, bidirectional, and reverse links are all AgSimple types. What set them apart from one another are the BiDirectional and Reverse properties, which must necessarily be included in the export template.
Therefore, you will need to create a new export process, add these properties to the template, and then import them with the same export template.
NOTE: This solution applies to Elipse E3‘s versions equal or lower than 3.0. From version 3.1 on, these links can be exported automatically, with no need to have a template informed.
