Question:
There is a runtime hardkey running a domain in the server. But if I insert another hardkey (with an E3Studio license, for example), it will only be detected when E3Server stops. In this situation, how can I open E3Studio to edit the project without having to stop the domain?
Solution:
To do so, you must first plug the other hardkey to another computer on the same network, and then access it remotely to retrieve the E3Studio license. Via E3Studio, access the File\Connect, and then point it to the computer where the E3Studio license is.
