Question:
How does the I/O Driver’s ShareServer property work?
Solution:
If this property is set to True, the driver shares its execution with the other I/O Driver objects that have the same string in DriverLocation.
Thus, only the first configured I/O Driver will execute the communication’s start up; the others shared I/O Drivers will ignore all settings parameters.
The ShareMaximum property sets the maximum number of I/O Drivers that will be grouped on a shared I/O Server.
NOTE: There is no need to set up all other Drivers; the settings in the first Driver to be activated with ShareServer property will be used in all other Drivers.
