Question:
Since Windows CE does not have a C: folder, where should the I/O driver be placed when Elipse SCADA is using this platform?
Solution:
When working in an application for Elipse SCADA CE, all files in use must be in the same folder or subfolder of the application; therefore, the file has a relative path, and it will not be retrieved by the complete path.
