Question:
Does Elipse E3 communicate with IP cameras?
Solution:
Yes. To do so, insert a Frame and type the camera’s IP address on its SplitLink property. This can also be done via scripts, with Open Screen pick or OpenScreen method. Another possibility is using an ActiveX provided by amanufacturer: after it has been properly installed and registered, just insert it in E3.
