Question:
In an application, a tag contains the value in seconds of the device’s working time. How can I show this value in hours in a Display?
Solution:
To do so, you can divide the tag’s value by 86400 (24*60*60) on the Display’s source to show the value in hours.
Then, you must configure the Display’s format to show it in hours. For example: [h]:mm
