KB-26487: Editing properties of alarms in a Library at runtime.
Question:
How can I edit the properties of alarms that are in a Library at runtime?
Solution:
To do so, you must insert a property in the XObject for each limit or value to be edited and create a link to the property of each alarm that you want to edit.
Print Friendly, PDF & Email
Leave a Reply
