Question:
After inserting a Library into a Domain, the screen where the XControl was inserted does not open correctly at run time, and the following message is displayed:
“Browsing to the webpage was canceled.”
Why does this happen?
Solution:
This may have happened because XControls/XObjects were inserted with duplicated names, that is, there were other objects with the same name in another Library inserted in the Domain, which is also being used in the project.
