Question:
How can I connect the Viewer to a domain in another computer?
Solution:
To do so, you must execute the Viewer and, once the connection window is displayed, inform where the domain to be connected to is running.
You can also create a shortcut to the Viewer and pass the address of the computer where the domain is running as the parameter.
