Question:
How can I play different .WAV files according to the active alarm’s severity?
Solution:
To do so, there are two possibilities:
- Create user events in Viewer to test ActiveHighAlarms, ActiveLowAlarms, and ActiveMedAlarms properties at the same time to check which .WAV file should be played.
- Create user events to test ActiveAlarms property and, via scripts, use ActiveHighAlarms, ActiveLowAlarms, and ActiveMedAlarms properties to check which .WAV file should be played
