Question:
How can I create hot keys in E3?
Solution:
You can do so by using screen’s KeyDown or KeyUp events, where you can identify the code of the pushed key via KeyCode variable.
Example of script:
Sub MainScreen_KeyDown(KeyCode, Shift)
MsgBox KeyCode
Based on the returned code, you can create a script that tests this value and performs any other actions necessary.
For example:
Sub MainScreen _KeyUp(KeyCode, Shift)
if KeyCode = 112 then
MsgBox “You’ve pressed F1”
end if
For example:
end if
NOTE: The KeyDown and KeyUp events are executed only if the screen where the scripts were created is opened and has the focus.
Attached to this article is a sample application developed with Elipse E3 version 3.1 build 270.
