KB-24726: Connection between E3 Viewer and E3 Server is lost when using network board Marvel Yukon 88E8001/8003/8010.
Question:
When using the network board Marvel Yukon 88E8001/8003/8010, sometimes E3 Viewer does not connect to the E3 Server. Why does this occur?
Solution:
This occurs because there is a bug in the network board of the computer executing the E3 Server. To fix this, update the network board’s driver. It can be downloaded here.
Print Friendly, PDF & Email
Leave a Reply
