KB-23095: Element count in a block tag.
Question:
I’ve added a 10-element I/O block to a driver folder, and even after one of the elements had been deleted, the option Tag counting still indicates the same 10 elements as before. How does the element count in a block tag works?
Solution:
The total amount of elements in a block is indicated by its Size property. So, whenever you insert or delete elements from the block, you will have to change its Size property.
Print Friendly, PDF & Email
Leave a Reply
