Question:
How does Elipse Software’s supervisory systems’ communication via GPRS work?
Solution:
With Elipse’s systems, communication via GSM is transparent. Just configure the proper driver and, on its properties settings, select the IP address and the port for connecting the modem.
If the modem has no fixed IP, locate the IP of the computer running Elipse. To do so, in the Elipse driver settings, enable the option Listen for connection on port on Ethernet tab. By doing this, the software will wait for the modem connection, and then will start communication with the device.
