KB-19359: Disabling DateTime field in the Browser.
Question:
How can I set up DateTime field to not be displayed in the Browser?
Solution:
To do so, open the Database tab in the Browser’s properties, select the DateTime field and uncheck Enable option. Then, click Reload File Structure button.
Print Friendly, PDF & Email
Leave a Reply
