Question:
How can I add fields to alarms so that the query to Alarms table returns the values from alarms, plus the values from the added field?
Solution:
To do so, you must configure the four fields on the tab User fields, in the alarm server. In the query/browser/chart, select the added fields so that they can be correctly displayed.
In the query/browser/chart, you must be careful to select the added fields, so that they are correctly displayed.
