KB-17964: Loading the text of the last active alarm into a script’s variable.
Question:
How can I load the text of the last active alarm into a script’s variable?
Solution:
To do so, you can use the Alarms’ GetInfo(“Comment”) function.
Example of script:
Dim aux
aux = Alarmes.GetInfo(“Comment”)
MessageBox (aux)
Print Friendly, PDF & Email
Leave a Reply
